Lost keys?!?!?!
  • Thread starter Thread starter billison
  • Start date Start date Dec 4, 2006
billison
I like tinted tail
2,607
1,094
184
stl
Dec 4, 2006
  • Dec 4, 2006
OK i'm looking at a parts car that has the keys lost but good title, and i'd need to drive it home, is there a easy way to bust the colom and start the car
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Dec 4, 2006
  • Dec 4, 2006
a hammer and a flat screw driver is always easy......or smash (take apart) the column apart and take the cylender out and use something to turn the ignition
billison
I like tinted tail
2,607
1,094
184
stl
Dec 4, 2006
  • Dec 4, 2006
yeah i think that'll be the way to go, i'm just getting it to part it out so i'll probly just bust it up good
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Dec 4, 2006
  • Dec 4, 2006
I think there is a rod that goes through the column that you can push instead of turning the key.....if you can bust the wheel lock to allow yourself to drive it
bubba-dough
1,044
Indiana
Dec 4, 2006
  • Dec 4, 2006
Or instead of tearing things up. Take the key cylinder out and remove the tumblers. Takes a little more time but nothing gets broken.
BlooDReigN
283
Calgary, Alberta
Dec 4, 2006
  • Dec 4, 2006
Or ask your all your buddies with fox bodies if you can test their keys in the car...Theres not alot of different key cuts for fox bodies...Odd's are pretty good you know somebody with a key that fits.
TRWXXA
190
RIGHT BEHIND YOU!!!... Made you look.
Dec 5, 2006
  • Dec 5, 2006
If you do this, make sure you have the title and/or bill of sale with you. If a cop looks over and sees that smashed column, you WILL get pulled over.
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Dec 5, 2006
  • Dec 5, 2006
lots of ford keys are interchangeable...sometimes for ignition only..sometimes locks....sometimes both. A buddy of mine had a contour and his key would start my 94GT, a minivan, and unlock various other cars...scary
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Dec 5, 2006
  • Dec 5, 2006
because our ignition's sukass....Ford ignition's in general
Quikstang
846
Orlando FL
Dec 5, 2006
#10
  • Dec 5, 2006
  • #10
another way is to take the collumn apart, and you will see the ignition switch its like tan and silver, unplug the plugs then take out the two screws on the inside... You can then actually push the switch enough to allign the pads that need to make contact and start the car... You will see what i am talking about if you take it apart... then you dont have to break ****... i had to do this about 5 years ago in college when i lost my keys on spring break...
billison
I like tinted tail
2,607
1,094
184
stl
Dec 5, 2006
#11
  • Dec 5, 2006
  • #11
I dunno if i'm gonna get the car now i'm thinking about doing a 5 lug swap, but i'll post more if i get it or not
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
