Loud Fuel Pump
  • Thread starter Thread starter Bhikku
  • Start date Start date Nov 10, 2010
Bhikku
44
SLC
Nov 10, 2010
  • Nov 10, 2010
the fuel pump is really loud in my mustang, so i assume that it might be going out soon.
how difficult is it to replace? i also don't have a garage, apartment life ftl :/
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Nov 11, 2010
  • Nov 11, 2010
The pump is easy to replace. Getting access to it can be a little tricky, especially if you have power steering. One of the easier jobs tho.
However, I've never seen/heard a loud mechanical pump. Are you sure that the noise is coming from your pump?
Bhikku
44
SLC
Nov 11, 2010
  • Nov 11, 2010
well it's definitely coming from the rear/trunk area. i don't think its the motor for the power radio antenna, and i think the pump is the only other thing back there, i could be mistaken though.
Hairy W Bush
59
Florida
Nov 11, 2010
  • Nov 11, 2010
so you have an electronic pump?
Bhikku
44
SLC
Nov 11, 2010
  • Nov 11, 2010
i believe so, but i could be wrong.
it's loud when not started but the keys are at the first turn.
DukeGnarley
597
Auburn/Ellensburg, Wa
Nov 11, 2010
  • Nov 11, 2010
how loud? you should be able to hear an external electric pump.
Hairy W Bush
59
Florida
Nov 11, 2010
  • Nov 11, 2010
an electric fuel pump would omit the mechanical fuel bump, which is on the driver side of the engine block. in it's place would be a fuel pump blockoff plate.
Bhikku
44
SLC
Nov 11, 2010
  • Nov 11, 2010
it's a rather loud hum, it can be heard inside the car when the engine isn't on.
if it's supposed to be loud, then great!
DukeGnarley
597
Nov 11, 2010
  • Nov 11, 2010
it sounds about right, as long as it's not making a rattling sound or squeaking or something you should be fine. The reason it's louder than on most cars is that most use internal pumps and the sound is muffled by the gas.
PoppyMod
617
Severna Park, MD
Nov 11, 2010
#10
  • Nov 11, 2010
  • #10
Hi Bud,
A loud electric pump is not unusual. There are pumps that are less noisier than others, though. The key is in it's consistent behavior. Hearing the "hum" of pump after making the "first key turn" is not unusual. Depending on your engine's muffs you may not hear it at all while running.
How long have you owned this car?
Bhikku
44
SLC
Nov 11, 2010
#11
  • Nov 11, 2010
  • #11
yeah it's pretty much a constant sound, and i can't really hear much over the sound of the V8 so im not sure about the sound when it's being driven.
and i've owned it for a couple weeks now.
PoppyMod
617
Severna Park, MD
Nov 11, 2010
#12
  • Nov 11, 2010
  • #12
OK. You might consider, crawling underneath or wait for an oil change interval, and see if the isolation bumpers are in place. These are little rubber washers on the mounting bolts to reduce vibration transmission to the body.
Happy Motoring!
Bhikku
44
SLC
Nov 11, 2010
#13
  • Nov 11, 2010
  • #13
Happy Motoring!
hmm i'll see if i can track it down
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 3:50 PM
AeroCoupe
Fox Prepping a '91 to start after 5 years sitting?
  • 331strokerGT
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 16, 2026
limp
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
M
05 Mustang GT With Annoying P0463 Issue
  • Machbud
  • Oct 17, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 24, 2026
manicmechanic007
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
