Low beams don't work
95stangcobra
So my low beam lights don't work on my 95 mustang. I already replaced the headlight switch with new connectors and I tried a new switch also and the low beams still don't work. My parking lights work and high beams work. I've searched and I have read that it could be the multifunction harness? Is that the only other thing that I should check? Also I have looked at the fuses and made sure the light bulbs aren't burnt.
try a dmm
Have you tried to back probe the connector to see if you have power to the low beams? Most of the time when somthin does not work at all it is an open ground. Not to insult your intel. but back probing can be done with alligator clips on your dmm and couple of push pins just probe the back of the connector (not through the insulation of the wire) and you should find source voltage. Let me know what you come up with.
~Chris
