  • SN95 4.6L Mustang Tech
low compression
  • Thread starter Thread starter Guled22
  • Start date Start date Aug 17, 2006
  • 3
First Prev 3 of 3
G
Guled22
61
#41
  • Aug 27, 2006
  • #41
ok another quick update, just threw a code and now it says cylinder 1 misfire. so since I switched the coil packs would that be the reason since the misfire moved?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Aug 27, 2006
#42
  • Aug 27, 2006
  • #42
yeah.. the coil pack is your problem then.. I just looked at the diagram.. what was number 4 is where the number 1 wire will go when you swap them so replace that coilpack and your car should be fixed..
Be sure to update us on this..
G
Guled22
61
#43
  • Aug 27, 2006
  • #43
cool, i just got two new duralast ones from autozone. i drove the car down the street earlier, and had it idle for about 20 mins do you think fuel got into the fresh oil? and do you think the cylinder 1 got fuel wash too?
BurningRubber
1,865
24
58
Aug 27, 2006
#44
  • Aug 27, 2006
  • #44
Damn man, you deserve an award... you could have just saved him some serious money...
Pretty sweet to have a Ford tech on the boards to help everyone out.
G
Guled22
61
#45
  • Aug 27, 2006
  • #45
I know huh, he just saved me $1500 in debt. but all jokes aside thank you for all your help man i really appreciate it.
Mike97gt
it doe snot
10,633
Aug 27, 2006
#46
  • Aug 27, 2006
  • #46
As long as the oil looks and smells normal you should be fine, I doubt you ran it very long misfiring like that. You might have to clean the number 1 plug and reinstall it.
so how does it run with the new coils?
Thanks
G
Guled22
61
#47
  • Aug 27, 2006
  • #47
i have the new coils in, and it runs smoother than the day i first bought it lol. I highly doubt its going to throw a code because its running so smooth. So yea thanks again man, I was so close to having the engine rebuilt for no reason.
BurningRubber
1,865
24
58
Aug 27, 2006
#48
  • Aug 27, 2006
  • #48
Man, think how pissed youd be after they rebuilt the engine and the misfire was still there cause they used the same bad coil pack...
Wow, I would come out swinging... lol.
T
Torinalth
952
Clayton NC
Aug 28, 2006
#49
  • Aug 28, 2006
  • #49
OT but this is one reason i stay around here... if anyone with experience leaves the site and moves off to the elite sites, or part spacific sites, then there would be a lot of unhappy mustang owners with nowhere to turn. yeah it sucks losing experienced people that can help, people like SVT around here help a load of people daily. Granted i cant help with much, but i wont be leaving so i can repay what i have gleaned. good feeling.
Nice on SVT.
Torinalth
Mike97gt
it doe snot
10,633
Aug 28, 2006
#50
  • Aug 28, 2006
  • #50
LOL tell that ford dealer they can have me come work for them, but I would need 35 bucks per flat rate hour with a 60 hour guarantee.. plus I want my own IDS setup and for them to pay to relocate my family out there..
stangGT97
1,299
Boston area, MA
Aug 28, 2006
#51
  • Aug 28, 2006
  • #51
svttech FTW! :SNSign:
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 28, 2006
#52
  • Aug 28, 2006
  • #52
I just went through the same thing (No 6 misfire.) with my Expedition. I swapped plugs and wire and seems to have taken care of the problem. Of course the misfire has been there a while so I'm hoping it stays right. Good info here if I have to run down a gremlin. With 196K miles I don't expect much but this thing still runs pretty good.
Mike97gt
it doe snot
10,633
Aug 28, 2006
#53
  • Aug 28, 2006
  • #53
You should be fine now, once it's runnign right you don't have to worry about the effects of fuel wash, but to be sure check the oil and make sure it's not loaded with fuel
CanadaStang
2,093
Mb
Aug 29, 2006
#54
  • Aug 29, 2006
  • #54
It makes me wonder what the mechanics you took your car to actually tested. As I said previously, the compression on the cylinder in question would have to be very very low in order to be too low not to fire. If they would have at least discovered the coil pak issue [an ignition test should have been one of the very first things to perform] and then still could not have been able get that cylinder to fire, then at least one could perhaps blame fuel wash but they didn't even know there was a problem with the coil pak.
That is precisely why I had suggested checking that cylinder for compression, if it was less than 50psi then there would be no point in checking anything else, if it was less than the others but still acceptable, then the problem is with the ignition and fuel wash is causing the lower compression.
Mike97gt
it doe snot
10,633
Aug 29, 2006
#55
  • Aug 29, 2006
  • #55
I agree 100 percent. I can't speak for the rebuilding and machine shops but there is a lot of morons and hacks in general repair both at the dealers and the private shops. Many techs just don't have the skill or don't care to spend the time.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Aug 29, 2006
#56
  • Aug 29, 2006
  • #56
Not to mention the 1500 smakers they collect.
stangGT97
1,299
Boston area, MA
Aug 29, 2006
#57
  • Aug 29, 2006
  • #57
this is why I am very skeptical about having other people working on my car unless I know them well or have heard lots of positive testimonials.
BurningRubber
1,865
24
58
Aug 29, 2006
#58
  • Aug 29, 2006
  • #58
Preach on. Thats why I want to go to automotive tech school. So I can do everything myself, and work at a shop or dealership, and not rip people off...
CanadaStang
2,093
Mb
Aug 29, 2006
#59
  • Aug 29, 2006
  • #59
I personally have not had any issues with machine shops but, like you, I've seen alot of very poor work come from engine rebuilders, dealers and private shops.
  • 3
First Prev 3 of 3
  • Gulftown980x
  • Jul 29, 2026
squeak93
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
A
2020 Ford Mustang GT P0036, P0138, P0141 02 sensor help
  • AmkoA
  • Jul 29, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 5, 2025
skkrtis
