Low rpm stumble
GhostDog
Hesitates and stumbles below 2 k rpm
Fine at idle fine in neutral fine aboce 2k
Changed tps made it worse
Cleaned maf no change
Trying coil next
Then going plugs/wires
Any help appreciated pulling my hair out
99 3.8 v6 mustang
In the interest of being through don't overlook the role that a bad alternator diode could play in problems such as this.
Howto perform charging system voltage drop test
Given the relatively low price of spark plugs why not do them as well? This will give a chance to perform a visual inspection of the spark plugs which gives a good indication of combustion efficiency. This also offers an easy way to look for things like anti-freeze in the combustion chamber.
