  • SN95 4.6L Mustang Tech
Lower temp. thermostat
  • Thread starter Thread starter turboscrew
  • Start date Start date Aug 3, 2004
T
turboscrew
131
  • Aug 3, 2004
Are there any power gains to be had by switching to a cooler thermostat, say like a 180 deg.? i think the stock ones are 210 deg. Right? I put Autolite 764s in Sat. Would that hurt or help with a cooler therm.?
A
AREJAY
83
Snohomish, Wa
Aug 3, 2004
  • Aug 3, 2004
It helps. Particularly in hot weather. Cooler is better. I would also dump a bottle of Amsol Waterwetter down the radiator when you do a flush and replace the coolant.
stangman
2,690
10
69
in a 3 bed, 2 bath
Aug 3, 2004
  • Aug 3, 2004
192 is the stock thermostat. your car will benifit from running cooler obviously, but to take advantage of the cooler thermostat you need to get either a electric fan switch, or have the fans tuned on at a earlier temp. by way of a chip or tuner
billyfe390
573
  • Aug 3, 2004
If you get your fans set lower a 180 is great but never under any circumstances go cooler than 180.
T
turboscrew
131
  • Aug 3, 2004
Does the computer have the set temp. to turn on the fans?
stangman
2,690
10
69
in a 3 bed, 2 bath
Aug 3, 2004
  • Aug 3, 2004
yes
propellerhead
1,541
"but what's with the but shots?"
Aug 4, 2004
  • Aug 4, 2004
From http://www.mustangworks.com/articles/misc/StangFAQ.html#5
- Change (or remove) the factory thermostat
This is based on the fact that cooler air is denser, so the less you heat the air coming into the engine, the more air/fuel mixture you can pack into each cylinder. An old shade-tree mechanic fix, but it's got several strikes against it. First, you never want to remove the thermostat completely. The cooling system has been designed with the thermostat restriction in mind, and removing it will actually _hurt_ cooling. Second, cylinder wall wear increases as operating temperatures are lowered. The stock Mustang thermostat is set for 196 degrees Fahrenheit. Dropping to 180 will increase wear somewhat, and dropping to 160 or 140 will increase wear dramatically.
On EFI cars, cooler thermostats are rumoured to increase performance because the engine will run richer at temperatures below 180 degrees Fahrenheit. True, the EEC-IV will richen the mixture, but staying in "warm up" mode entails more than just a richer mixture. The EEC-IV will be more conservative with the timing curves, and will never get into "closed loop" operation (where it uses the oxygen sensors to fine-tune the mixture). The result will likely be poorer drivability and _decreased_ performance. Also, catalytic converters can be damaged over time by an engine that's continually running rich.
VERDICT - Don't remove the thermostat entirely, and don't use a thermostat below 180 degrees Fahrenheit on an EFI car.
K
kawasakizx7r
17
  • Aug 4, 2004
Need some help,please.
I was going to lower my t-stat,but for now iam running stock.
What should the car run for temps at the gauge "NORMAL" mines at
"M" right now and seems to be hotter then it should and thats at normal driving and 70-80 degree weather.
Would like it at the "O" but having a hard time doing so,any tips??
I recently flushed the cooling system and new thermostat.
billyfe390
573
  • Aug 4, 2004
Thats probably normal because the stock guages arent very accurate.
K
kawasakizx7r
17
#10
  • Aug 4, 2004
  • #10
You think so?? I just bought this car,so iam trying to figure out
whats up,so the seller can dish out some money,if its something major.
My next step was to change the temp sending unit and see what happens,
maybe i will just buy a new gauge also?? Probably not,but iam desperate.
I have a "95" gts and it sits at "N" all day long,hot or cold!!!
Thanks.
billyfe390
573
#11
  • Aug 4, 2004
  • #11
Thanks.
you could just go to a shop and have them see how hot the top radiator hose is but most of them run around 200 degrees and that seems to register pretty high on the guage.
W
wickedgt70
178
San Jose, CA
Aug 4, 2004
#12
  • Aug 4, 2004
  • #12
Kawasaki, try some Water Wetter if you haven't already. That stuff works pretty good. Follow directions on the bottle. As long as you're not in the high range or fluctuating from low to high all the time you should be alright.
K
kawasakizx7r
17
#13
  • Aug 5, 2004
  • #13
hooked up a scanner,its reading 200-205 at "R" and 210-218 at "M",so i guess its normal,still want it under 200,but i might have to change the stat for that or get a better radiator.
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
