  • 1994 - 1995 Specific Tech
lowering spring intall
  • Thread starter Thread starter mustang_cab
  • Start date Start date Jul 19, 2007
1 of 2 Next Last
M
mustang_cab
18
Baton Rouge, LA
Jul 19, 2007
  • Jul 19, 2007
how much so i expet to pay to have someone put a set of lowering springs on my car? (eibach pro kit springs)
M
mustang_cab
18
Baton Rouge, LA
Jul 19, 2007
  • Jul 19, 2007
i know i didnt put a "s" in install
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Jul 19, 2007
  • Jul 19, 2007
Don't do it man. Put them on yourself!
GTA_V6_Mustang
1,326
Miami, FL
Jul 19, 2007
  • Jul 19, 2007
If you lived in South florida I would be more than happy to help you with the "intall" lol
Bosko5.0
1,067
longwood, FL
Jul 19, 2007
  • Jul 19, 2007
http://www.stangnet.com/tech/spring.html
D
DarkStallion095
93
Rancho Santa Margarita, CA
Jul 19, 2007
  • Jul 19, 2007
spring intall (install)
Sorry I just had to. Hey I always catch my "intalls" by proofreading. Anyway your looking at about buck fifty to 200 bucks. I think that is what I paid. Unless you know what your doing, just pay to get it done.
GTA_V6_Mustang
1,326
Miami, FL
Jul 19, 2007
  • Jul 19, 2007
You know in the article he mentioned something about removing the Strut from the strut tower. I dont think thats necessary.
M
mustang_cab
18
Baton Rouge, LA
Jul 19, 2007
  • Jul 19, 2007
I really want to try it myself i just dont have the know how yet. What would probly happen is that i would get it apart and some thing would go wrong and i would have to get it towed to the shop to get it fixed. which would coast even more money. so ill leave it to the experts for now. i wish i had some friend that worked on cars to help me. i need new friends. lol
I see yall are not my friends making fun of me about my mis-typing. lol
demon40
69
canton, nc
Jul 19, 2007
  • Jul 19, 2007
Lowering springs
Hey man where are you located at
M
mustang_cab
18
Baton Rouge, LA
Jul 19, 2007
#10
  • Jul 19, 2007
  • #10
Baton Rouge, LA
demon40
69
canton, nc
Jul 19, 2007
#11
  • Jul 19, 2007
  • #11
Well i was going to say if your close to canton, NC i could help. Ive lowered 5 mustangs by my self so i know what to do just from experiance. Really the only thing you need to do is put the car on jack stands, remove the wheels. Jack the a-arm up to relieve the pressure on the strut and sway bar end links. Remove the strut from the spindle, and remove the end links. slowly let the jack down untill you can remove it, and let the spindle fall to the ground, now the spring should come out fairly easy. ( be careful the stock springs have a lot of pressure on them.) reverse the process to put it back together. Repeat on other side. The rear you have to take the shock and quad shock loose and let the axle drop, use a jack to let it down so you can control how fast it drops. Do both side at once on the rear. Once you have all four rear shock loose and the axle dropped you'll have to pry on the stock springs a little bit to get them out but they dont have no where near as much pressure on them. reverse the process on the rear to put it back together. Besure you turn the springs the same way the stock ones were turned. It will definatly need to be aligned after that.
HISSIN50
34
129
Jul 20, 2007
#12
  • Jul 20, 2007
  • #12
It's too bad that only half of the 94-95 section is from LA.
I do agree that it's a hot idea to have a friend who has done it before watch ya.
To the above write-up, I'd add that I loosen the front LCA bolts before allowing the LCA to drop (and the spring to come out). This relieves stress on the bushings.
demon40
69
canton, nc
Jul 20, 2007
#13
  • Jul 20, 2007
  • #13
LCA bolts
+1 on the bolts. Just forgot to mention that part. If you decide to do it yourself and need some assistance Send me an e-mail and i can give you my cell phone number
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Jul 20, 2007
#14
  • Jul 20, 2007
  • #14
OT ...
Demon, I see you are in Canton. I was up that way last weekend (Swannanoa). I'm just down the mountain there. Car looks nice ... got any pics?
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
Jul 20, 2007
#15
  • Jul 20, 2007
  • #15
mustang_cab said:
Baton Rouge, LA
I live in Opelousas, LA, and there are a few other guys that live in BR.
Springs are really easy to do. I really dont think you could mess them up. I did mine in like 7 hours by myself. (dont do it by yourself. lol)
Bosko5.0
1,067
longwood, FL
Jul 20, 2007
#16
  • Jul 20, 2007
  • #16
the hardest part is to remove the front springs( unless you have the spring compressing tool. And get in the top strut bolt undone(unless you have air tools.)
I would say save the money for something else. isn't stanger007, and sage2k are located in baton rouge, LA I would say hit them up with a PM and see if they are able to help you.
And I was going to use that install that i posted since i had the same springs but it was really a straight forward so I didn't use it.
The Green GT
1,269
Louisiana
Jul 20, 2007
#17
  • Jul 20, 2007
  • #17
Its easy to get the front springs out if you un do the sway bar. The A-arm can go down far and it will just fall out almost.
The hardest part for me was getting the rears in. Ihad to push the rear end down and put them in at the same time.
Bosko5.0
1,067
longwood, FL
Jul 20, 2007
#18
  • Jul 20, 2007
  • #18
place jackstands under the axle before you remove anything. it makes it so much easier.
SeventyMach1
Mar 30, 2005
1,940
North Carolina
Jul 20, 2007
#19
  • Jul 20, 2007
  • #19
No spring compressing tool is needed. Some people literally kick the spring to get it out. I was going to attempt this ... but could not get at the spring with the right angle to kick it out.
My suggestion (if you have a problem getting the front springs out) ... which I did not ... would be to get a long rope. Tie one end of the rope to the bottom coil. With the control arm being released, you have plenty of room to tie a rope to the bottom one. Pull the other end of the rope. This gives you plenty of room to clear out of the way if the spring was to go wild on you. Call this redneck if you will, but I have heard of people doing this and it works.
M
mustang_cab
18
Baton Rouge, LA
Jul 21, 2007
#20
  • Jul 21, 2007
  • #20
hey thanks for all of the help. i have contacted a few guys to see if they were interested in assisting me. so ill let yall know what they say. i might just get one of my friends and just go for it. thanks!
1 of 2 Next Last
Ebay Lowering springs
  • Canyonred86
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Qtrhrse23
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
Habu135
68 coupe rear drop
  • Butchd88
  • Apr 3, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 19, 2026
C.R.M.
Fox Valve Spring Kit PAC-1219X. Help finding needed additional parts.
  • 93gtmustang
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 31, 2026
93gtmustang
