Lowering spring W
If you only want to buy the parts once, stick to the entire MM catalog, most of the rest of the kits out there are going to rattle.
I seriously doubt you bent a stock front control arm. The bushings or ball joint could be shot, but bent? I just can't see it.
Adding tubular MM control arms is going to be costly, with little to no benefit.
Contact MM to get personalized advice for your setup.
I actually am thinking of changing to a 275# spring at some point
I wouldn't bother with a 25lb change, I don't think it's different enough to justify the work or money.
If anything goto 300lb.
I often wish I went to 300lb, but I can't see that minimal change being worth the effort.
Reactions: Mustang5L5
