  • SN95 4.6L Mustang Tech
LT Headers
  • Thread starter Thread starter funcrusher
  • Start date Start date May 11, 2004
F
funcrusher
27
Virginia
May 11, 2004
  • May 11, 2004
I just bought BBK's LT headers and matching x pipe and already have a flowmaster cat back exhaust. How long and how hard is the installation of the headers and x pipe
Also I just installed a vortech supercharger s trim running 10 lbs of boost and am adding the headers and x pipe as well as 55 gallon/hr fuel pump and 30 lb/hr injectors and adjustable fuel pressure regulator what kindo of horsepower should I expect to see off od this configuration?
thanks a ton in advanced
R
Roger_4.6_96
1,209
Reno,NV
May 11, 2004
  • May 11, 2004
Are you going to get your car tuned ? if you added all the stuff your adding i would get a tune with a supercharger. its hard to install LongTube Headers, might as well have a shop do it
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
May 11, 2004
  • May 11, 2004
Do a search...i recall seeing a thread not too long ago about LT install. i heard the install is very time consuming....like working a whole weekend on it. i would take it to a shop to have it done if i ever get some LTs. just search though...i bet there is a ton of info already here on the site
C
CottonBurnerz
Banned
May 10, 2003
1,554
Drink and Drive = Teh Lose
May 11, 2004
  • May 11, 2004
i have lots of pics in my site... that might help.. do a search and you'll get plenty of info as well..
Trublu01
SPRAYMAN
6,673
Loxahatchee, FL
May 11, 2004
  • May 11, 2004
Drop the K-Member and the install is no problem at all. And definatley get a tune after headers.
2Slow96GT
22
South Carolina
May 11, 2004
  • May 11, 2004
I think the longtube install is actually pretty simple. Yes it is time consuming, but for the most part pretty simple. Me and a friend worked probably 5 hours and had it done right the frist time.
stangman
2,690
10
69
in a 3 bed, 2 bath
May 11, 2004
  • May 11, 2004
if you have all the right tools & can get it in the air, it's not as hard as some people say. but i had it done on a lift & we dropped the k-member. with that out of there it was soooo much easier. becareful letting the k-member down though, because it's a lot heavier than you think
R
rob1
94
Indiana
May 11, 2004
  • May 11, 2004
If you're getting the heads swapped anyways would headers be that hard? They will have my car on a lift as well doing suspension and gears.
Thanks
lman657
85
  • May 12, 2004
Actually, it sounds overwhelming, but it's easier (in my opinion) to pull the engine to do a headswap/ header install. You can drop the engine in with the headers on, and the headswap part of it will be much faster not being leaned over a fender. Only an opinion though
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
D
Fuel pump upgrade
  • dkrupp79
  • Jul 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 10, 2025
Scrapla347
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
