Terrible experience with M&R!!
I have been holding off for a long time on posting this awaiting a final outcome. Well the day has come and is it not pretty.
The following is a chronological review of what has occurred and my awful experience with M&R motors.
• Purchased a 383 stroker full turnkey in 8/2008 from Danny at M&R. Limited communication after purchase. Motor arrived over 4 weeks late, the block was the wrong color, the fuel lines leaked, the valve covers were loose and the order was missing the fly wheel.
• Within a few weeks the motor was consuming oil, blackening the oil and leaking oil. Emails and phone messages to M&R were not returned.
• Approximately 800 miles after install in 5/2009 oil problems got worse to include loss of oil pressure and a rattle. M&R advised a possible faulty PCV valve and valve cover baffles. Unbelievable. By the way, Danny had left M&R by this time and limited correspondence was now with Matt. They advised they would send a replacement PCV, valve covers or additional oil breather to replace the existing set up. Nothing ever arrived.
• Contacted M&R again in late 5/2009 as problems worsened. They casually advised me to pull the motor and return it for repair all on my dime. I never received a Bill of Lading after we spoke. After numerous phone messages to M&R I finally spoke with them and received shipping info. They assured me that you would call once they received the motor and would advise as to what failed on it.
• Once again left numerous phone messages with no reply. Finally reached them but they were very evasive as to what had been done to the motor. They mentioned incorrect stud length in oil pump and two glazed cylinders. They assured me the motor would be dynode, an inventory of repairs would be shipped with the motor and tracking information would be sent.
• After a few weeks I never got any correspondence and called the office again. They stated motor shipped.
• Finally received motor after weeks of waiting. No information shipped with the motor. Motor was missing the clutch pilot bearing on the crank (so I can only guess they replaced the crank), the water pump was barely on, other closures were hand loose. I do not believe the motor was ever dynode before shipping. They were unable to produce dynode sheets and the condition of the motor did not lend itself to having been dynode.
• After installing motor for the second time had oil leaking from the intake seal in the rear, the timing cover and valve covers. Also had oil spraying out of the two breathers once the engine was hot. Also hearing random rattles again from motor.
• In 8/2009 I took the car to a local performance shop immediately after the motor was installed to be dynode and tuned due to lack of power. Initial numbers were way off and very disappointing. Had two different professional Chevy engine tuners work with the motor. Both have extensive experience racing and tuning. Both noticed that the fuel pump did not have enough pressure and was making noise. Replaced existing faulty fuel pump with an Edelbrock high flow pump, replaced spark plugs again, changed out the carb jets, adjusted the timing and re-dynode the car multiple times. No change in motor output. Motor was supposed to dynode at 440 at the flywheel. Rear wheel HP dynode between 270 and 285. Experts agreed something wrong with the motor and no more HP is achievable. Still hearing rattles at this point.
• Sent email to M&R on 9/04/2009 conveying my disappointment with performance and overall experience. No response. Called multiple times and finally spoke with Matt. They asked me to fax the dynode records and they would get back with me. No reply. I called again numerous times and finally spoke with Matt again.
• After conveying my anger, disappointment and frustration I pointed out the options. We go to court and I contact the BAR in CA, they refund my money or reimburse my additional expenses and repair the motor again. They stated to pull the motor again and send back to them again for repair. They stated they would monitor the repairs, dynode the motor, turn it around quickly and provide an explanation of the repairs. They said that if I put together a list of additional expenditures they would reimburse me. They assured me that all messages would be returned ongoing. To date and over a year and half, I have never received a call back from one of my messages left at M&R.
• Almost a week goes by and no shipping information. I leave messages and finally speak with Curtis who is one the mechanics in the back. He doesn't remember repairing the motor the first time nor can he explain why it was a returned in sloppy condition the first time. Although no call backs from them I finally I get the shipping information emailed to me.
• Motor is pulled, fluids drained and prepared for shipping. Oil is black again but less than 300 miles on motor since last install. I cut apart the oil filter and find metal particles. Also metal particles in the breathers. Something is obviously wrong with the internals. Ships out on 10/8/2009 for the second repair.
• No communication from M&R for over two weeks and then my motor magically reappears with no paper work and no reimbursements or dynode sheets as promised. Further, the bolt attaching the harmonic balancer is broken off, one spark plug boot is torn and another spark plug wire is melted. My motor is also covered with tape adhesive.
• I call and speak with Matt who once again is evasive as to what they did to the motor. He claims he has been too busy to get me the dynode paper work but that it hit 420 at the flywheeland there was nothing wrong with the motor. I ask about the rattle and he states they might have adjusted some valves. These guys are amazing at the lies. Matt once again promises to send new valve covers and dynode paper work. That was three weeks ago and I have nothing from them.
• As I warned Matt, I took the motor directly over to another engine builder to dynode and assess. Numbers came in at 385 at the fly wheel and still hearing rattles. The motor is being torn down as I write this for a complete salvage/rebuild to get the motor I was originally seeking.
• After two failed attempts to repair and make it right, a year and half of time wasted, thousands in additional expenditures I have had it with their lies and the BS. The whole situation has been unacceptable and the quality of service and product has been abysmal. I have been more than patient, calm and willing to work with them on resolving but to no avail. I offered again for them to just refund my money and just let us quietly go our separate ways but they opted to continue the charade. This motor purchased from M&R was obviously not mechanically sound and is unable to produce the performance I paid for and M&R sold/advertised. Once my tear down is complete I will be seeking restitution.
Bottom line is avoid these guys at any cost. My experience has been an absolute frustrating and costly nightmare. Their service is terrible, their motors are junk and the quality is atrocious. I cannot believe they are still in business and I certainly do not believe they ever could have built motors for Boyd Coddingtion.
If you have any questions just drop me a note.
