M/T Drag Radial tire pressure?
DK832
291
Copenhagen, DK
So I'm finally going racing on my first ever set of drag radials.
It's a pair of M/T Drag Radials in 275/50/15 on a 69 Mustang Hardtop. What would be the right tire pressure for them on the track?
Info if it matters: I have 5-leaf rear springs and Competition Engineering Slide-a-Links, 3.70 gears.
(I run Nitto drag radials - friends with the M/Ts use this same logic)
I'd start at 20 or 22 and go down in 2psi increments until you get to around 16 - see how it hooks.
I usually end up at a slightly different PSI each time out at the track depending on how it is prepped and what the weather is doing.
Wes
