M2300k problems
mwc50
Hi, I have fully installed the m2300k kit on my 93 GT. Now my brakes in the front are dragging! like I am applying the pedal. It gets worse the more I use them. I followed the directions to a tee. The pedal feels awesome and the brakes stop well, but its like they arent releasing all the way only in the front. The brake bias is set on four turns from all the way in. the stock prop valve was modified, everything taken out and capped. I thought maybe the large booster had some residual pressure on the master from the rod, but I loosened the master and held it out a bit to see if that was the problem and no difference. Any ideas? My car is only making about 12" of vacuum but i dont think that should matter either. Any stupid things I am overlooking?
Thanks,
Max
