mach 1 vs 00 gt
tomustang said:
not really, they just have a live axle to play with over the cobra
You sure?
The Cobra's were rated at 320 HP and most runs Ive seen magazine wise are mid-upper 13's.
The Mach's are 300 HP, and run mid-low 13's in the same mags.
Does the solid rear axle give it that much advantage at the strip over the IRS?
BurningRubber said:
You sure?
Well they only made two year model Cobra's that were rated at 320hp. Only the 2001 (not 1999) had the actual 320hp. The 99's had roughly around 290-300.
The 03/04 Mach 1's are rated at 305hp, but actually put out probably around 320hp from what I have seen in their rwhp numbers.
Solid axle does help a bit with take-off, nothing special.
The 01 Cobra's run mid-13's...and just a tick lower...
Yeah my bad, should have said I was reffering to the later model non s/c'd Cobra's, not the first 96-98
s. Didnt Ford have a recall on the 99 Cobra's for not making the whole advertized 320 hp?
Yeah that is what I was talking about:)
I never referred to the 96-98 DOHC, just the 99's (a bit weaker) and 01's (true 320bhp)...
