Mach 1000 Questions
Hello there!
I just bought my first stang last night :D
it is a 2002 v6 model with all the options and leather and all that good stuff.
it has the 6 disk changer and mach labeled speakers, but i looked up some stuff on the mach 1000, wich i believe i have, and it says that there are subs in the trunk, and there is no sub of any kind in the the trunk let alone anywhere else!?!?!?
it sounds good, but it needs subs...
is there a model of ther mach1000 that does not come with subs?
thanks, and sorry im sorry if this is a requently asked question...
Shouldn't be too expensive. I think they changed the harness after 2001, so you might have to go to best buy or circuit ciry or a local installer, and they should have one. Not sure on the price, though.
thanks guys
i will talk to my local stero shop, and see if i can find some one that can maybe set me up with compatible configuration... of if any of you have done the same, tell me how it went, it would be greatly appreciated!!!
Thanx :D :hail2: :banana:
(sorry the little smile icons are great)
all ready have them...
got 2 10" JL audio W3's and a Punch amp with like 500watts bridged at 4ohms....
just seeing how the heck its all gonna fit together, want to use my previous deck, it has a front and rear preamp out put, but no sub out puts, so...
i was thinking of use the the front out put and split it to the two amps for the front and rear speakers and run the tweets off the 57watts x 4 i have in the deck, and then use the rear out preamp for the subs....
is that all possible?!? :shrug:
