Mach 460 Aftermarket Install Help
98E9GT
110
Well I took out my factory headunit and installed my roommates kenwood cdplayer. I was getting a whining noise matching with RPMS. I started going over everything and found the connect which connects the Amps to the wiring harness had a loose connection, so after jiggling around some wires(they kept pushing out too) It finally works, perfect. So if anyone is having problems try doing that. Also check your grounds and if nessicary create your own ground to complete the Ground Loop. Peace:flag:
