Mach 460 wiring help
tarmak_rcr
15
Ok guys, I got the mach 460 and the wirring that goes from the back deck box to the front. Question is there is an extra plug at the end of it where it goes into the radio, It is a female with 2 holes. Now i Have the radio with the push buttons, am I missing something that the digital one that would normally be in the Mach 460 would have? Also there is another female plug near the rear box that is about 2 feet into the cord going up front, is this just an extra for the mach 1000 or does it go into something?
pictures, here is the two plugs at the end, the one goes into the radio if im correct, where does the second smaller 2 hole female go?
Here is the back of my radio, stock push button cassette, this is where im assuming the plug from the rear speakers goes into, now where would that 2 prong female go and what happens to the old plug that is taken out?
finally here is the extra plug in the back, where does this go, is it a dummy for the mach 1000 ?
it appears so but i'll ask to make sure...its the mach 460 setup with the main headunit and then seperate slave cd player correct? if so it doesnt look like you have the correct wiring , i just pulled mine out and i def. dont recognize the female 2 hole
Is the mach deck hooked upto a power supply at any point? im thinking possible that the 2 hole female is a power supply hookup, ground, and hot. anyone got any ideas on this?
