Ive been searching for a few weeks trying to figure out a problem
Sofar what i understand in my 1994 Ford mustang GT running a Mach 460 System however, i put a few different speakers since when i got the car they were ALL blown, whatever, i had a few laying around.
In the front i have the same size Infinitys, they work great, however in the back
the Amplifier is pushing 6 Ohms and then going by 3 ohm? i cannot figure this out..
I want to know what the ohms required for the bottom rear speakers are for the stock mach 460,
My rears i switched from the normal Mach 460 speakers to Rockford Fasgate 6 x 9 4 Ohm, They work at low volume up to 16-17 (also running a JVC 40x4 head unit) When i turn the volume passed 16-17 the speakers either bottom out or just quit,... I dont know what is going on, and if i need to bypass the amps, or just remove the amps, what could i use to replace them, however, im also looking into putting a sub in it. I'm not really good with cars audio, so if you understand anything that i just said please anything can help
To long didnt read ;
replaced stock mach 460 rear speakers with 2 rockford 6 x 9 4Ohm, and it bottoms out, Any reason to why??
Also, If needed to buy different amps, which ones could i get that would work, and allow me to run a subwoofer..? Im confused about this and havent found an exact answer to my question..
OH AND PS :
Are the stock mach 460 rear speakers running at 6Ohm speakers? 8 ohm? 4 ohm? Google isnt my friend today :/
OH AND PS :
didnt like the mach 460s they are horrible :/
