Mach 1 Mach I Exhaust Tip size?
red94fiveo
1,269
Wichita, KS
Just like the subject says, what is the size of the Mach I exhaust tips? I love the rolled look and was hoping to score a set from somewhere for my car. Hopefully their 2 1/2" or 3". Oh, and how far back do the tips go with the larger diameter. Thanks.
TR03Mach1 said:
You might want to run a tape measure past them again, 'cause mine measure 3" OD :rolleyes:
I never measured them in the first place, I just figured that they were 2.5 since that's what my GTs tips were. Thanks for the correction. :nice: Weird though cause my magnaflows look a helluvalot more then .5 inches bigger then the Mach 1 stock tips.
red94fiveo said:
Am I reading your sig right that you have a cat-back on the Mach 1? If so would you be willing to part with your old exhaust tips, cause I want them.
Actually I'm thinkin of reusing them on my Ford Ranger if I put split exhaust on that puppy. But I'll let you know if I'm not gonna use them. :nice:
The Magnaflow tip will look bigger since their not rolled.
My Magnaflow 3 1/2" rolled tips came today, so Im going to put the ones that came with the system on Ebay.
The reason I like the rolled tips is you can see them from behind. Regular slice tips all you see is.........."hole". :nice:
Will you post a link to that ebay auction? I'm interested. Thanks.
What's the part# and where did you order your Magnaflow rolled tips from?? :shrug:
I ordered the 2 1/2" inlet x 3 1/2" rolled tip.
#35113 from http://www.bestautopartsonline.com/tips3.htm
And Ill be dammed if their not right. Their actually 3" inlet x 3 1/2" rolled tip.
Way to BIG of a inlet. Their website is screwed up. And so is this place!
http://www.a-1parts.com/performance_store/magnaflow_stainless_exhaust_tip.cfm
I checked Magnaflows website and sure enough, both sites are screwed :mad:
Here is Magnaflows part numbers. http://www.magnaflow.com/02product/tips/truck.htm
As you can see the #35113 has the 2 1/2" inlet. I emailed bestautoparts and Im demanding replacment # 35114 for no additional costs. I just hope 18" is not to long.
Dennis
I haven't forgotten you. Now that my rolled tips are not right, I might have to use the Maganflow tips for a few days till the replacements come.
Course if it dont get any warmer, I might not be getting the Mach out. :(
Thank goodness its not my daily driver.
Dennis
Don't the bullitts have the same exhaust tips??
Here's a set for sale on Ebay
http://cgi.ebay.com/ebaymotors/ws/e...tem=7923628579&category=33633&sspagename=WDVW
Two weeks ago, i scored a set of Mach 1 tips with less than 100 miles on them. Not a spec of soot or rust on them. They were cut about 3" after where the chrome ends so i have plenty to weld with.
Thing is, i'm not sure i want to use them. I think i want some bigger 3.5" rolled tips. If i go with those, i might be looking to sell my Mach tips
