Made less numbers on the dyno, but I didnt change anything?
Hey on Friday I tried to finally finish my car. We strapped it down and it put 329 down first run. Last time I was there I made 338. Next try i made 367 but Paul said it was because of my clutch slipping and it really wasnt that high. After somemore tuning it was back to 320-330 but never above 330. What happened? I didnt change anything since last time I was there. I thought I would make some more power with a chip and some tuning but I lost some? Dyno time was cut short becausse of leaking coolant but it wasnt my HG from what I know. So far it looks to be my waterpump.
Here is a graph of the the time before where we had NO tuning(just dropped f/p a little). Could those bumps in the power curve be from my clutch slipping cause they wouldnt go away.
Sorry reading comp owns me. missed that. there is still some margin for error but your right. I would have hoped to pick up a few HP from the chip and air temp. Who programmed the chip. can you go back to your original tune and re dyno? Your original tune might have been a little less conservitive then your new tune. better safe then sorry. Where was your timing and A/F last verses now?
well there is also one other factor that could be at hand.. I have found this out personally. The belt on the blower could and probably slips. I have went from 9 psi one run to 12 the next to 8 the next...
I always thought that blower belt slipage was just an excuse guys came up with till i saw it do it on my datalog. You could see how it would climb and then come down cause it would start to slip...
The only cure for this is a cog system that i know about.
