MAF And IAT
tjh566
608
Northern Va
Ok, I just got my pro-m pro-tube the other day and it is of the 6 pin type, now I have the adapter for our cars down to the 4 pin.
My question, the other 2 pins is a built in IAT correct? If so Can I cut the wires going to our IAT and put them in with this built in one and if so which wires go to which pins?
I'd keep your OEM IAT and simply not use the new one. IIRC the two outer wires are for the IAT on a 6 pin (check that).
If it's like an LMAF, it'll be something like:
1: Not used_____ 2: A_____ 3: B_____ 4: C_____ 5: D______ 6: not used
This is just an example. Be sure to check your wiring for your parts and application.
Gotcha. Maybe Wes, Don or one of the other tuners will know if your MAF's IAT is calibrated similar to ours (or can be recal'd when you tune your car).
Bumpity for you.
