MAF and injectors
4.6L97
mesquite
if I were to run 30lb injectors with my 7psi supercharger set-up.......and I run a 90mm lightning MAF...will they work together? if not how do you get the maf programmed to run the 30lb injectors?
I agree you need bigger injectors. If you get your car dyno tuned they can adjust that all in the tune. You can get a base tune from them to drive your car over to the dyno. Also jmschip.com sells tune/lightening maf/injector combos, youll just have to call them and give them your setup. I bet Modularpowerhouse does too.
