MAF code
  • Thread starter Thread starter Goldcuffs
  • Start date Start date Mar 16, 2008
G
Goldcuffs
43
  • Mar 16, 2008
I don't know if you guy's can help much because the info that I have is limited. I was going to wait until Monday to get all the info but it's bothering me so here it is. I have an 89 LX 5.0. I did the mass-air swap using only the body from a 96 4.6 T-Bird. I used my original sensor. Now I am getting a check engine light, I don't remember what the code # was but the definition was "mass air flow out of range". Do I need the sensor from the T-Bird as well or are they the same? Thanks in advance for the help.
HISSIN50
34
129
Mar 16, 2008
  • Mar 16, 2008
It sounds like you answered your own question. The sensor and housing are a married pair. If for instance you use a stock sensor in a MAF housing that's larger than the stock housing (a perceived performance upgrade), more air is ingested by the engine than the computer realizes. This can create a lean code (rich adaptive limit).
I have the feeling this might be what occurred (though I know nothing of T-bird meters) because otherwise there'd be no reason to use a MN meter housing.
Look into a 94-95 Mustang MAF swap. You'd use the 94-95 F2 meter and 70 mm housing (keeping them a married pair). The meters are cheap in the used market.
Good luck.
vristang
4,933
101
124
Seattle
Mar 16, 2008
  • Mar 16, 2008
Post the part numbers on the tbird sensor....
That may be the right one for you to use....
G
Goldcuffs
43
  • Mar 16, 2008
That was the problem, I only have the housing. It bolted right on but apparently I need the sensor to go with it.
G
Goldcuffs
43
  • Mar 18, 2008
Sorry this took so long, I finally tracked down the sensor number. F6SF-12B579-AA
G
Goldcuffs
43
  • Mar 20, 2008
Anyone?
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
