Its not too hard to do, i have done it one time and the hardest part was swaping out the pins in the pcm connector. Thats about all you need , you do have the air box or cold air intake?
lol yea I have a cold air intake, so I have everything I need to do the swap? Where do the wires coming from the mass air meter goto? Is there any sites with step by step instructions for dummies like myself Thanks for the quick response.
Well the kit we used came with instructions, there should be somewhere where you can get some info on the wiring. That should be it. plus you have to cap off the map sensor witch was used as the bap sensor, now that you are going with the maf sensor.
i can't see the ends of the wires off of the mass air sensor, but you will need about 4 eec-IV pins to connect to the harness. took me about 20 minutes to convert and about an hour and a half to run the wires cause i couldn't decide where to route them.
