Maf For Boosted Project
  • Thread starter Thread starter JD1964
  • Start date Start date Jun 23, 2014
JD1964
there is enough sticking out to grab on to
3,647
1,669
194
Maryland
Jun 23, 2014
  • Jun 23, 2014
My sig has my setup.
I'm gonna add a Vortech V3 Sci (5-6psi). Got the SVO 30lb injectors already.
My question is regarding MAF for this application.
Can I use my current MAF (70mm from 94 Marquis) if I get a chip and have it tuned by a pro with dyno to match the 30lb inj? So far, two pros I've talked to question whether the current Marquis MAF will have enough electronic curve to cover the increased air ingestion. But I swear somewhere on here someone said my current MAF will work if properly tuned with chip in ECU.
Just looking for confirmation.
I realize these tuners are used to doing what they normally do. I feel like I'm asking them to step slightly outside of their comfort zone. One says I need to buy and aftermarket MAF, the other says maybe I don't and is willing to try.
Which way do I go?
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Jun 23, 2014
  • Jun 23, 2014
That maf will be pegged... If you are going to go to a tuner buy a slot style maf and put it in a 3" tube. Like an hpx slot maf. If not, buy a matched maf for your injectors.. I don't know if the 30lb injectors will be enough either..
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Jun 23, 2014
  • Jun 23, 2014
Shameless plug: I have a brand new Pro-M slot MAF with 3" housing and pigtail for sale.
JD1964
3,647
1,669
194
Maryland
Jun 23, 2014
  • Jun 23, 2014
Is this an uncalibrated maf that requires a tune? If so, I may want it.
JD1964
3,647
1,669
194
Maryland
Jun 23, 2014
  • Jun 23, 2014
I got a Kirban adjustable regulator already. I can crank it up if needed. Considering that, you think 30's are not enough?
RacEoHolic330
4,014
1,698
203
Allentown, PA
Jun 23, 2014
  • Jun 23, 2014
Yea. The slot mafs don't require an injector calibration, but a tune is necessary with them. I'll shoot ya a PM.
JD1964
3,647
1,669
194
Maryland
Jun 23, 2014
  • Jun 23, 2014
I wanna keep my 65mm TB. Is that gonna be a problem?
RacEoHolic330
4,014
1,698
203
Allentown, PA
Jun 23, 2014
  • Jun 23, 2014
That shouldn't matter. With a blower, I would assume you'll be using a draw-thru MAF, so it will probably be in you fender with a filter on the end.
pearlnotchback
5 Year Member
Dec 18, 2011
319
44
59
Tennessee
Jun 23, 2014
  • Jun 23, 2014
Im running 30lb injectors with 6lbs of boost with no problems.
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Jun 24, 2014
#10
  • Jun 24, 2014
  • #10
Yes that should be enough if you adjust pressure or use a fmu. I personally would get big enough injectors and get rid of variables like messing with pressure, and just let the professionals take care of the adjustment in the tune. I know my 94-95 70 mm maf was just about pegged with a gt40 setup, so I would buy a new maf at least.
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Jun 24, 2014
#11
  • Jun 24, 2014
  • #11
R u sure about that? A blow thru was recommended to me when I turbo my car. Is their a difference between using a turbo or sc? I would imagine boost is boost, but maybe not.
RacEoHolic330
4,014
1,698
203
Allentown, PA
Jun 24, 2014
#12
  • Jun 24, 2014
  • #12
Nearly every centrifugal supercharger setup will run a draw-thru MAF, simply because it's easier to do so. A blow-thru MAF would require a custom or modified discharge pipe. On the opposite side of the coin, it's better for turbo guys to run blow-thru because of all the intercooler piping. A draw-thru meter would put the meter quite a distance from the engine and could cause a noticeable delay in what the meter reads and what the engine sees. The turbo could also create backwash through the meter on a draw-thru setup, and that's something that cannot be tuned around. You don't usually have those concerns with a blower setup.
f8tlfiveo
Aug 8, 2007
1,585
102
64
Lancaster, PA
Jun 24, 2014
#13
  • Jun 24, 2014
  • #13
Ok, that explains it. Thanks for the clarification, made perfect sense.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jun 24, 2014
#14
  • Jun 24, 2014
  • #14
I have an AFPR that has been sitting, brand new, in a cabinet in my garage for probably 6 or 7 years now.
With a proper tune and sufficient injectors, stock fuel pressure is just fine for most typical builds at sane power levels.
Google "fuel injector calculator" and plug and chug your expected power levels to determine if the 30s will be enough.
Onefine88
Previously 89SSC18
1,422
796
154
Jun 24, 2014
#15
  • Jun 24, 2014
  • #15
30's will support up to 400rwhp by itself (without) an FMU. "At least they did for me on my SSC". I ran a simple 73mm C&L meter calibrated to the 30's and it ran great!
Once I upgraded beyond 400rwhp I went to 42's and 80mm ProM meter.
You can glance at my combo in Sig below to get an idea of what I've got going on with my vert.
No matter what you do, IMO you will need to seek a dyno and get the new supercharged combo tuned.
madspeed
Colonel Mustard
1,332
204
a van down by the river
Jun 24, 2014
#16
  • Jun 24, 2014
  • #16
To run it safely I woild also get it tuned
elarm1
1,428
652
154
N.Va
Jun 24, 2014
#17
  • Jun 24, 2014
  • #17
Why not just shoot for the SI? It will be independently tuned and you will get your own injectors. Might as well upgrade now
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
2K
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
help me understand calibrated maf sensors and injectors
  • stackz
  • Sep 21, 2024
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
AeroCoupe
