today at school i hooked up one of the scan tools and it said my maf was bad. The cars been cuttin out alot lately do yall know where i could get a new one and if getting a new one will mess up my dyno tune?
takes longer than a minute. more like 30 mins doing it that way.
he could disconnect the battery and then turn on hte lights or something of that nature to reset them.
I always remove the ground and turn the ignition on to clear my KAM. If anything is stored in the capacitors in the pcm that will remove it.
I don't know if the headlights would work. I have heard depressing the brake pedal before, so I guess that would be the same.
But I still don't get how you are supposed to discharge a capacitor with no ground for the current to flow. JMO.
Scott
if i grab a the sensor out of a gt will i be able to put that in my pro-m housing and have that work?
always seen them gone
Another thing I have noticed![]()
When they did not clear .....
I noticed my digital dash clock
did not reset to 12:00
Now ... about a ... Quick Reset
Yes ... From what I've seen said ... Its about discharging the Caps
and
I usually give it around 5 seconds to discharge
I have tried the following with success
and
In each method ... I saw the 12:00 reset as well
Headlights
Horn
Brakes
