MAF to big?
94_5.0
337
Jacksonville, NC
would a 80mm MAF be too big for my engine set up with 30# injectors and a 70mm T/B? Or would a 75 or 76 MM MAF be better suited for my set up?
I will be adding a single turbo (66MM) my engine later on, so I am trying to plan a little bit a head.
ok wait is this a blow through MAF or a draw Through? Draw through the bigger the better blow though you want to keep it at 75mm with a no bigger then 70mm TB with a 66mm compresor wheel....you can go bigger but the intake pipe coming of the turbo to the intake is likely only to be 2.5in some are as small as 2in....this is to keep Volcity up.
