maf
  • Thread starter Thread starter gwiesem
  • Start date Start date Oct 19, 2006
G
gwiesem
18
  • Oct 19, 2006
is there any advantage of getting a new maf meter besides more air flow.i hear alot of bad things on here about aftermarket maf meters.im still using stock injectors,thumper heads,mild comp cam and cobra intake.also t5 with 3.73,mac shorties and an off roadf x-pipe.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 19, 2006
  • Oct 19, 2006
94-95 Mustang GT MAF - $40-$100. It is 70 MM instead of the stock 55 MM on regular stangs built prior to 94. It uses a slip on duct on the side that goes to the throttle body and a 4 bolt flange on the other. You need a $25-$35 flange adapter from Pro-M to fit the stock slip on air ducting that goes to the air box. Wiring plugs right in with no changes.
I got a metal flange adapter from Powered by Ford for $35 and tax. That was over a 2 years ago. Summit Racing may also have one too.
Powered By Ford
1516 South Division Avenue
Orlando, FL 32805
Hours 0800-1800
Phone 407-843-3673
http://www.poweredbyford.com/
larrendeuce
649
Southern NJ
Oct 19, 2006
  • Oct 19, 2006
I have read about the problems with using an aftermarket maf and it leads me to wonder. Do the 19# mafs have a similar function and curve to the stock maf?
vristang
4,933
101
124
Seattle
Oct 19, 2006
  • Oct 19, 2006
What MAF's do you mean?
The stock Ford 70mm MAF mentioned by JR, uses nearly exactly the same MAF Transfer as the stock A9* MAF meter.
After market MAF meters are not all that bad.
There is potential for problems because you are 'tricking' the computer on both airflow and injector size.
The error in airflow can cause issues with timing and injector pulsewidths because of how the error can affect the Load calculation.
Many folks who run aftermarket MAF meters, never have any serious issues.
I am one of them... I have had great luck with my 73mm C&L.
Some will emphasize the 'luck' in that statement though
If you can get away with the stock 94-95 70mm MAF, I would suggest sticking with it.
If you do need the bigger injectors, then go ahead and go aftermarket on the maf. Most likely things will work out quite well.
jason
91lxttrim
194
AZ
Jan 28, 2007
  • Jan 28, 2007
Is it possible to use the stock MAF with bigger injectors?
vristang
4,933
101
124
Seattle
Jan 29, 2007
  • Jan 29, 2007
Only with a custom tune, preferably on a dyno with a wideband
D
Tune erased/wont start/91 fox body
  • drew123
  • Jun 15, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 7, 2026
drew123
D
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
C
Dyno day! # guesses?
  • clayton seiders
  • Aug 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2025
Scrapla347
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
