Well my problem is with my Exhaust Tips on my Magnaflow Exhaust System. It is a re-occurring problem. The "Allen" screw gets lose and the frigging tip rattles like no ones business. This will be the third attempt to having this problem resolved. I work at a Ford dealership and last time I had a Ford Tech put it on a lift and tighten the screw up and throw some lock-tight on it....well as it happend that screw has since cracked. Now before I buy new tips and kill these...I was hoping anyone had any ideas or suggestions????
So I busted out the trusty Dremel and whacked an inch or two off.
Luckily, the burn spot isn't visible, since it is inside the bumper. Anyway, I ended up getting my tips welded. Since I had no intentions of adjusting them again, I figured that would be the best solution for me. After that, no significant problems even though they aren't perfectly aligned (about 1/4 inch off)
