Sinultros said:I had a similar problems, only the driver's side tip actually moved BEHIND the rear bumper and burned a tiny portion of the paint off!Luckily, the burn spot isn't visible, since it is inside the bumper. Anyway, I ended up getting my tips welded. Since I had no intentions of adjusting them again, I figured that would be the best solution for me. After that, no significant problems even though they aren't perfectly aligned (about 1/4 inch off)
It's barely noticeable though.
Mine (driver's side) kept hitting the swaybar when I run over bumps or dips on the road. I had the muffler shop "bend" the pipe, and no more knocking sound since.
GinoGT said:I had the same problem......it wasn't the screw for me. The metal rod that the tip hangs from (the LONG metal rod) was actually so long that it was resting up againt the clamp of the exhaust tip.So I busted out the trusty Dremel and whacked an inch or two off.
No problems since.![]()
Totally disagree. The tips are very nice. The cool thing is that they allow you tou adjust them to exactly how you want them. It isn't a Magnaflow quality problem that the user is not doing small tack welds to hold them on ... I did when I got mine ...01'TRUE BLUE GT said:Cheap @ss Magnablow tips ...
01GT eibach said:Totally disagree. The tips are very nice. The cool thing is that they allow you tou adjust them to exactly how you want them. It isn't a Magnaflow quality problem that the user is not doing small tack welds to hold them on ... I did when I got mine ...
BLKVERT said:Well my problem is with my Exhaust Tips on my Magnaflow Exhaust System. It is a re-occurring problem. The "Allen" screw gets lose and the frigging tip rattles like no ones business. This will be the third attempt to having this problem resolved. I work at a Ford dealership and last time I had a Ford Tech put it on a lift and tighten the screw up and throw some lock-tight on it....well as it happend that screw has since cracked. Now before I buy new tips and kill these...I was hoping anyone had any ideas or suggestions????![]()
edcar01gt said:quit complaining and just weld the sh** together....damn why do you got to make everything so GD difficult....making the rattling stop in't gonna make u any faster...so get in ur car, take it the muffler shop and get the sh** welded.....![]()
BLKVERT said:Well thanks for the advice just trying to save my Magnaflow tips before I toss them...not like there mojo tips anyways. This from a guy who's name indicates he drives an '01, yet he has a pic of a Mach 1 in his avatar???![]()
Firemanz said:We'll have to hit up Hooters next week.......
