Magnapacks on the way
topnotch
24
The Magnapacks are on their way from NINOSPORT. Once I go to installing them, is there anything I should know before hand about this cat-back (does and donts and what to look out for)
Install took me about 2 hours. It would have taken me a 1/2 hour less if I hadn't spent so much time trying to twist and work the old pipes out and over the rear axle. Just go ahead and hacksaw them - thats what I did. Other than that the Magnapacks are good stuff, I hope you like them, cause I sure like mine!
lock thight the set screws for the tips (youll see when you get the kit) and keep an allen wrench to fit them with you for about a week or 2 as they loosen up and fall out, what kind of mid-pipe are you running stock or catted youll be ok, but do not go with an off-road you lose too much backpressure
