Well in the past month I have completed:
T5Z Conversion, Hydraulic Clutch, Stainless steel brake lines converted to dual exhaust setup, Maier mid eye leafs w/ poly busing kit, Bilstein shocks, dual bowl master cylinder, FPS step headers into new 2.5" pipe with new flow 50's, and Maier Sub Frame connectors.
I had my exhaust shop weld up the sub frame connectors while they were under there, and I am surprised at how low these hang under the car. I assume that is normal? They are definitely installed right and are as tight as they can be to the mounting areas, just wasn't expecting them to be so low. My car is lowered, so I'm sure this just makes the problem look worse than it really is. Anyone else with sub frame connectors feel the same way at first sight?
I hope I notice as much a difference with these as everyone else that has tried them!
