Here is my problem. I recently put together an 86 bocl 5.0 for my 84 mustang. The engine builds excesive pressure in the coolant sytem and blows out the radiator cap when sufficent presure is built up. This ocurs when revving the engine and driving, but not at idle. I have tried just about everything to diagnose the problem but have had no sucess. The engine does not overheat acording to the gauge. Here is what I have done so far:
Checked water pump and replaced
Checked and replaced thermostat
Found cracked E7 head and replaced with a know good head
Tested block for cracks(used tool that determines if combustion gasses are in the coolant system)
Flushed sytem
Checked and confirmed that head gaskets are installed correctly(part labelled front is located at the front of the engine)
Checked radiator flow.
At this point I am thinking that there must be a blockage somewhere causing a hot-spot and stream which is blowing out the radiator.
I was thinking about disconnecting the radiator and blowing compresed air through the block and heads.
I am looking for further advice and furhter diagnostic procedures. Please help. I am not sure what to do at this point.
Flushed sytem
