I had my brake line fixed on my right rear today. When I got to the shop they put my car back on the lift to show me that the right rear suspension is ripping away from the frame. The bracket that holds the upper control arm to the frame is cracked almost completely through. Also the whole right side of the rear end support is pulled away from the bottom of the car enough to stick you hand behind it. There are a couple of other spots that have moved as well. This explains why my brake line was moved away from the frame. I am going to the dealer in the morning to let them see the problem. Has anyone else had this problem?
Also should I worry about taking off any of my mods? I am going to change out the prochamber with the stock pipe, but that is all I had planned on taking off.
Guess it's never a bad idea to put it back to stock before going in though.
