So I finally made it to the point where I could mock up my heads on my motor, and begin checking my piston to valve clearances. I got a set of 1.7 Crane roller rockers off a 93 cobra(oem) and mocked up the heads, valve springs, and rockers, etc. I have heard that I must maintain at least 0.100" of clearance on my intake and exhaust valves during the engine cycle. Well, long story short, I'm running way too tight on my p-t-v clearance. I used a new head gasket, laid one of the heads on, installed light weight check springs, and finger tightened two head bolts to secure the head enough for testing. I also used the comp cams adjustable pushrod checker to find the right pushrod length. Then, I hooked up my dial indicator, and the testing went as follows:
Checked my indicator at these points in the stroke:
20 deg. before tdc and got a reading of 0.264" (okay, I'm thinkin that's good!)
15 deg. btdc- 0.202"(okay, still truckin')
10 deg. btdc- 0.151"(gettin concerned a little)
5 deg. btdc- 0.106" (uh oh...
0 deg. TDC- 0.075"(oh no!)
5 deg. after tdc-0.051"
10 deg atdc- 0.042"
15 deg atdc- 0.047"
20 deg. atdc- 0.074(so then it opened up wide again after that)
So I repeated the test again, and unfortunately yielded the same results +/- 0.005"
How do I fix this???? I am running the cam advanced 2 degrees, and I think if I retard it 2 degrees, it may help some, but I am not sure if it will be enough.....I need advice!!!
Oh yeah, I am also using the sealed power/felpro gasket set #260-1169 from sumitt, but it does not specify what my head gasket thickness is...
)0 deg. TDC- 0.075"(oh no!)
10 deg atdc- 0.042"
15 deg atdc- 0.047"
