i know the best way to compliment a new intake is a bigger tb and new mass air...with my setup should i run a 65mm tb and 70mm mass air or shouold i go larger???....how about 24#ers??? the engine wiil be untouched for awhile because i need to upgrade the worn suspension, and the body needs some work and paint as well....when this is done ill either rebuild the engine or opt for a fresh 306 keeping the intake and adding trick flow heads and cam in both situations
