- Feb 4, 2004
- 516
- 0
- 16
Two things get in the way of big front tires. The fender and the shock tower outer brace. The fender can be worked to fit a larger tire and so can the shock tower brace. On a track car with a lot of neg. camber the shock tower brace can get in the way.
I found that if I made a cut just behind the hole for the bump stop, most of the brace on the back could still be used.
I made a paper template for the 1/8" plate that will be welded in.
A shot from the back showing the stock brace I will be welding to and the piece I cut out.
Here you can see how much was taken off. It's a little over 3/4".
Once again I have to thank Cobra Automotive for the idea. It only took a few minutes and should give me the room I need to run 245/45/16's up front. It will all get welded up and ground smooth. I could even bolt on a smaller bump stop if I wanted too. Free mods are the best.
John
John
