making some progress
95opal
5 Year Member
Nov 16, 2004
449
20
39
making some progress "Update"
Well the winter project is starting to come around. Just got the bay cleaned up and sprayed. Going to try and get it assembled by the end of the weekend. Thats if I get all the parts back from powdercoat in time to bolt up to the motor. Still have to get the rear brakes on, rims&tires mounted, side skirts sprayed and on, amoung numerous other misc. stuff. Guess i still have a ways to go, but im shooting for 2 weeks.
looks great but may I ask why you made boxed holes in the fender
Behind the drivers side hole is the fuse box and the other is for the CAI. I have covers with a couple of dzus fasteners to secure them. Just need to get the block in to mock up the CAI and cut the hole cut for the tube. The fuse box is faceing the engine bay so I can get at it if need be. I saw how everyone just smooths out the apron and figured it be a good idea, this way i dont have to get at everything through the wheel wells. The MAF will be in the fender so that would be a hassle to take out every time I wanted to clean the filter.
that looks amazing. i'm with clark, kicking myself for not doing the same thing when i had the engine out.
curious why not put a k-member in. went through all that work why not finish it off. money?
Prokiller, I didnt go w/ the k-member cause this car is 100% for the street and I didnt see any real benifit of doing it and I read some cons to going w/ an aftermarket K wich I didnt want. Plus the MM kit was very steep price wise.
Trav, the guy who sprayed my car also did the engine bay, and yes he can really lay some nice paint. He still has the saleen skirts to hit and the cars body will be finished.
Very nice, and I like the idea of the fuse pannel access area...you could almost put a plexiglass cover over it like a show sterieo install with the fuses showing.
Very smooth looking I hope to do something like that at somepoint, just a clean up and paint bomb has to do for now.
What did you have powdercoated?
reason I ask I had my acc. brackets coated silver metalic along with my alt. done in chrome. I found it gave me a HUGE charging issue as the powdercoat would not let the alt. ground. I ended up sanding down the areas that mount (touch) to that bracket on both the alt. and bracket to allow a good flow threw it. I also sanded down the area of the bolt behind the belt tens. so it would ground to the block.
blksn955.0, I had all the brackets and intake powdercoated mirror black, the lower and waterneck got aluminum powdercoat. I had them place disks over all the mounting holes in the brackets for that and other reasons. I went over every part with the powdercoat guy before they were shot. I just spoke with him today and he said i can pick everything up tomorrow, which will help keep me on track for getting the motor back in by the end of the weeked. I will post up the pics of the powdercoated stuff after i pick it up. I cant wait to see them especially the upper intake.
Thanks for the props guys but i owe it to my body guy. Without him I never would have even considered doing it. So I just want to say thanks Ron from RS Paint & performance. :hail2: :nice: :Teh-Win: :banana:
It seems like every thing is falling in place nicely, I just got back from powdercoat with all the stuff I needed to get this motor in over the weekend. So it seems like I will be on track to finish in the next 1-2 weeks. I leave you with these pics of the powdercoat stuff and im off to start assembling the motor.
