Making the rounds - DT out on the track last weekend
steel1212 said:
If you use the calculators with 396 hp you should be at 11.44 lol. Don't they make a AOD that you can put in drive and it works like a normal auto or you put it in 1st and then have to shift it?
All AODs do the former for driving, but for racing you want more control over the shifts. The problem with the latter is that the early factory shifter is PRNDL and latter classics are PRND21, both are short a gear or two for manually shifting the 4-speed. Lentech has a work around for that and all you need is their valve-body.
dodgestang said:
408W :nonono: it is a 408C :rolleyes:
I knew that, sorry!
