hey all,
Been having some trouble since I relocated out to Kansas from PA. First of all the car ran great on the 1150 mile trip out to Kansas and ran great before hand. Since getting here I've had to replace the throttle body cause the throttle shaft broke. I replaced the dryer connection to the S/C with a boostmaster pipe for better air flow and hoping to keep out some of the heat. After that its been down hill. It seemed that something happend to the S/C belt adjustment and the belt was slipping. I found that the lower bolt threads were stripped and let the pulley move a bit to slacken the belt... got that fixed. With full boost again it seemed that the clutch was slipping so I loosened the cable a bit. When I took it out for a ride everything seemed good but the car just died as I was coasting about 60 MPH. I checked the codes and had a memory code 14: Ignition pickup was erratic and 22: MAP (vacuum) or BARO signal out of range. After searching the forum I found code 14: I needed to replace the stator (or PIP). So I replaced the distributor (old TFI). Now I'm thinking I was getting detonation. Car seems alright if I slowly go to WOT but if I hammer down the car seems to stutter with no get up and go. Not really clutch slipping cause the RPM's don't shoot up. Took the car out for a ride yesterday and at first it seemed that I still had detonation if I jumped on it but seemed OK if I gradually went to WOT but didn't have full power. I rechecked my codes and KOEO is the same old 15, 85, 95... memory was 1,1... 1,1. Did some more reading and found that area elevation can effect detonation. On top of that I have only been able to get 91 octane out here and my car is tuned for 93.
Do I need to back off my timing a bit to compensate for the elevation difference and fuel grade? use some octane boost? or is something else going on here? Could it be that the MSD coil or 6AL is going out? I don't have any issues starting. Don't want to just throw more money into it to try and find the problem. Any input is appreciated...
. So after spending about $100 in parts and $70 in gas (and $50 more on the way with new plug wires since I broke one of the boots when changing the plugs) a $8 filter fixed the problem.
