MAP sensor question........
  • Thread starter Thread starter twizted91gt
  • Start date Start date Jan 21, 2004
T
twizted91gt
46
Dutchess NY
Jan 21, 2004
  • Jan 21, 2004
Is there supposed to be a vacuum line going to the map sensor on the firewall?....there appears to be a small "nipple" of some sort on it with nothing plugged in....reason im asking is im having some crazy idle problems as of lately(damn 10 degree weather) and its driving my nuts so i thought this could be a possible solution.............thanks
9
93cobra12
531
Seatte, WA
Jan 21, 2004
  • Jan 21, 2004
you could have a vacuum leak, or your tps could be dirty, check your MAS plug, make sure thats all plugged in.. If you have emisisons, check all the sensor lines make sure there all plugged in.. if not, you should try starting it when its warmer outside.. if not, go have the codes tested.. good luck !!
P
PRO50SC
1,012
Olney, Maryland
Jan 25, 2004
  • Jan 25, 2004
There's not supposed to be a vacume line to the map sensor.
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
Engine 94 GT breaking up
  • 996stang
  • Sep 21, 2024
Fox 5.0 Mustang Tech Sep 26, 2024
AeroCoupe
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
