mass air conversion
  • Thread starter Thread starter nasty5pt0
  • Start date Start date Aug 26, 2007
N
nasty5pt0
  • Aug 26, 2007
hey guys, i have been researching all over the forum about everyones methods & problems for doin the conversion... i have an 88 gt, and i converted it to mass air. i got the complete engine harness and computer out of an 89 i believe it was. everything was all well and good until i put the cam in (tfs stage1), 1.7 rockers, 30lb injectors and 30lb mass air meter. the car surges, stalls and misses. will not stay running. timing is on (about 14* or so), i got about 43lb's of fuel pressure which stays consistent. i have good vacuum. cleaned the egr out.new tps sensor. new iac valve.... just a little frustrated at this point and any help would be of great appreciation. i am just curious if there is something i have to change in the harness on the dash side of the harness??? it almost feels like its an electrical failure or sensor because the problem is so intermittent. thanks for the help in advance everyone.
88mouse
630
Mooresville nc
Aug 26, 2007
  • Aug 26, 2007
Injectors are to big for your set up right now IMO.
BTW what are you going to do with the old wiring harness?
grey5.0beast
Cookies should never be DUNKED!!!
Aug 3, 2004
atl ga
Aug 26, 2007
  • Aug 26, 2007
No heads?? Injectors are wayyy too big. Get a set of 19s and and borrow a stock MAF to see if it fixes it. PM me and I'll give you a stock MAF and a set of newer 19#ers for cheap. Hopefully that'll fix it. I'd save the 30 #ers for a nice set of heads!
N
nasty5pt0
  • Aug 26, 2007
yeah stock heads.... i dont have the stock mass air meter or injectors either.... u think it would really make a difference??? before i put the cam in, the car ran fine w/ the 30lbers....
heres the deal: it wont stay running unless i keep feathering the gas, once i let 1st out it will pull OK ( still missin a bit) and if i mash it sometimes it will pin me in the seat but then it will fall flat on its face out of no where like i turned the key off... and it will come back on , then off... its the weirdest thing.. i had a couple of friends look at it as well, they seem to think is has to do w/ the computer.. im not sure; if you guys think its to injectors/ mass air meter.. then maybe ill try and dig something up out of the junk yard and try that, as i already chucked all my stock parts....
also i already threw the old speed density harness out, sorry brotha!!! all i have is a mass air harness out of a 91 i think but it was no use to me because it was out of a car w/ air bags
strtrcr50
Previously from Dirty Jerzey exit 7a
Aug 27, 2007
  • Aug 27, 2007
You looking for a sd harness/computer?
cenok is family
1,409
69
79
Norman, Ok
Aug 27, 2007
  • Aug 27, 2007
im suprised no one's said this yet but pull the codes. i was having this problem up until the other day. i saw you said you got a new iac. a lot of aftermarket iac's require you to flip them upside down in order to work properly. i put a new mass air meter on my car and put my bbk cai back on, car was surging pretty bad, would stall when i came to a stop. i have an aftermarket iac from autozone. i flipped it upside down, surging problem solved. it idle's PERFECT now.
88mouse
630
Mooresville nc
Aug 27, 2007
  • Aug 27, 2007
I need another engine harness for my gt (took the factory one out and put it in my notch) I have a SD computer and a extra mass air computer. Just need another harness.
fiveohwblow
Official Member
2,169
145
155
Aug 27, 2007
  • Aug 27, 2007
Well I never run 43 lbs of fuel pressure either. that could also be a possible remedy. Make sure the car is not running and bring it down to 38-40 lbs and see what that does for ya. I know 30lbers are big for your combo, but it doesnt help when you forcefeed the fuel that way. Give it a shot...
N
nasty5pt0
  • Aug 27, 2007
thanks alot for all the input guys, i really appreciate it.... when i get outa work ill mess around with it tonight.... one question though, with the wiring.. i was reading the one thread that says you have to tap into the vss wire and the fuel pump wire and run it into the computer.... do i still need to do that even tho i changed the whole harness out w/ a true mass air harness?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 27, 2007
#10
  • Aug 27, 2007
  • #10
No. It is not necessary when you use a harness from a Mass Air car.
N
nasty5pt0
#11
  • Aug 27, 2007
  • #11
ok cool thats good to hear... i didnt get a chance to mess w/ it today, so tommorrow im gonna wrench on it a little and see if i can get it goin.. thanks guys
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
Aug 27, 2007
#12
  • Aug 27, 2007
  • #12
care if i ask a question in here so i dont have to start another thread?
N
nasty5pt0
#13
  • Aug 28, 2007
  • #13
no big deal, fire away
Fox Mass Air Flow 42lb injectors
  • 89wreck
  • Aug 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Scrapla347
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
