mass air meter install?
95WhiteVenom
624
Alabama
Well its going on first thing in the morning. Hopefully if i wake up ealry enough. Anyway is there any things to be careful of cause this seems like an easy install. I know whenever an install seems to be easy on my car its ends up being a PITA. :notnice:
So if all is well i'll have a few morning test runs with my new 80mm pro-m and filter the size of king kong.
Afterthoughs: damn i wish i would have just ordered that power pipe from AFM at the same time. Ohh well next week i guess ill order it.
95WhiteVenom said:
HAHAHA! Thanks i know ill be ready to drive it off a cliff in the morning!
you would be if you were trying to fit a AFM power pipe, i hear they can be a pita. but its nothing a little patience cant handle. Most of the people i meet seem to have negative patience though. :D
Yeah, the Anderson Power Pipe can be a little bit of a pain to install. On a fox body, you have to take a dremel or something similar to that and enlarge the hole on your fender to get the pipe to slide through. The hole has to be quite a bit bigger than the diameter of the tube also because you need room to position the mass air and filter in the fender well. They look good though once installed!
