Mass Air Meter
87_5.0
73
I have a powerdyne supercharger, and i know that the mass air meter goes before the charger, but i hear its not good to have a bend in between the air filter and the mass air meter. Is this true? Because i wanted to keep my mass air meter inside the engine bay then run a 90 degree pipe into the fenderwell and put a filter on the end. Is this alright to do or will it mess up the air calibration becuase of the 90 degree bend before the mass air meter?
Check out this pdf
especially Fig. 7
http://www.ceesi.com/pubs/117_Flowmeter_Installation_Effects.pdf
Basically, a bend will do nasty things to airflow.
What you want passing through the meter is straight non-turbulent flow.
jason
That is a great description and a good tool to use when people ask about "clocking" the meter to prevent or reduce surge and other driveability conditons. I ordered my mass air and with the bend directly in front of the meter they had to addrerss this in the construction of the electronics. This is a good example of why off the shelf mass air meters dont always work for everyone.
