I have an 88 foxbody. Car came with an automatic AOD trans and original 5.0 Ho. I spun the front main bearing, and front rod bearings. Coulndn't turn the crank anymore so I replaced the motor. Ran it with the motor like that for a while, 89 motor. Trans started slippin from the previous owner dragging the car. Pulled the transmission and converted it to a five speed. I naturally liked the 5 speed better so I rebuilt the AOD. Three weeks ago the fuel injectors started leaking. For monies sake I rebuilt them with new injector kits. Didn't fix the leak so I replaced the injectors with #24 injectors because I was told by someone who obviously doesn't know what they were talking about that it would work. They were the same price as stock injectors. Before the leak occurred I put a gt40 intake and heads on it. As I said before I plan on going bigger so I got bigger injectors. Car didn't run well because it was flooding so I got a conversion list from a site on the internet and followed it to a tee. I got the mass air harness and a 91 GT computer, to my understanding that is a mass air computer, if not somebody tell me, may be my problem also. I still have the problem because according to the guys on here it all has to be calibrated. None of this I knew, hence the problem. I don't want to go back down and buy stock injectors because that is that much more money that I could just spend on making my set-up work.
