Mass Air/Speed Density Experts
  • Thread starter Thread starter CRASH7772
  • Start date Start date Apr 16, 2004
CRASH7772
401
NH
Apr 16, 2004
  • Apr 16, 2004
I have a 87GT with a SD set up still on it. Can you run 24lb injectors on a SD car without any real problems? I have a Kirban FPR so the pressure can be adjusted and a 190lph pump. What about chips, does that help? I also have a Mass Air computer and harness out of a 89GT (not installed yet and I was told 89 is the year harness to get) but my car isn't equipped with cruise. Is it really worth trying to get the larger injectors to work on the SD or install the Mass Air and get the dsm (correct me if I'm wrong) switch installed to compensate for the non cruise? And isn't there some fuel bypass you need to do as well on the Mass Air swap? I guess I'm looking for my best way to cure the potential fuel problem of approaching 300+ hp. I'm not planning on going with power adders, just naturally aspirated.
bmorrisj
449
Buena Park, CA
Apr 16, 2004
  • Apr 16, 2004
you already have most of the pieces for a mass air convo, just get a 24# calibrated maf and put it in and your set......
CRASH7772
401
NH
Apr 16, 2004
  • Apr 16, 2004
I know but the whole not being a cruise control car and needing to wire up the sensor to the tranny and something about a fuel relay switch has put a damper on the conversion. I've had the pieces for over a year now, I even have a stock mass air sensor.
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Apr 16, 2004
  • Apr 16, 2004
You dont need the vss hooked up. I converted my 87 to maf and i didnt hook the vss up and I dont have cruise. I havent had any problems. Dont sweat it. The fuel relay is under the seat. You just run a wire over to the relay and tap into the correct wire so the eec knows the power is on. Not a big deal. Just follow the directions and solder the wires.
But to answer your question you can run 24# injs on sd. I ran my combo on sd for a long time and the swapped to maf.
CRASH7772
401
NH
Apr 16, 2004
  • Apr 16, 2004
Feel like a road trip to NH . The only problem is that it's not a kit so no instructions. It's out of a 89 mass air stang, the computer and harness.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Apr 16, 2004
  • Apr 16, 2004
Jump on ebay and buy one of those 30.00 conversion harnesses. It comes with the instructions and all. Its easy to follow and only takes 1-2 hrs. I did mine is 1.5 hrs. Thats the best way to do the swap. Its simple and it comes with all wires needed.
5.0Droptop
May 15, 2002
1,785
1,130
233
Indiana
Apr 16, 2004
  • Apr 16, 2004
Here it is
http://cgi.ebay.com/ebaymotors/ws/e...tem=2474257306&category=33553&sspagename=WDVW
87'GTstang
1,025
  • Apr 16, 2004
One of those things don't actually take the place of the harness from a donor car if you happen to have just a MAF meter and the A9l does it?
  • dan50
  • Jul 18, 2026
dan50
1987 Mustang GT Mass Air Conversion Help
  • mustangmike6996
  • Jan 1, 2025
Fox 5.0 Mustang Tech Feb 4, 2025
mustangmike6996
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
A
Resolved Fuel pressure high at 52 new FPR same thing
  • afjLX
  • Dec 28, 2024
  • 3 4 5
5K
Fox 5.0 Mustang Tech Jan 11, 2025
AeroCoupe
Engine Converting mass air back to speed density
  • a50ina50
  • May 20, 2023
4K
Fox 5.0 Mustang Tech May 29, 2023
mikestang63
