mass air wiring harness from 4cyl??
  • Thread starter Thread starter beaver2489
  • Start date Start date Jun 3, 2004
beaver2489
503
st. joseph missouri
Jun 3, 2004
  • Jun 3, 2004
If I can find a mass air 4banger, will the wiring harness from computer to under hood work on a 5.0? The mass air conversion I just tried...the harness I have is from 92 or newer and its not working? my fuel pump won't come on and I've checked everything..the wiring is ****ed and I don't feel like dicking with that ****ty wiring harness anymore. I wanna find a harness from an '89, but if its off a 4banger will it work? thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 3, 2004
  • Jun 3, 2004
No See http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp to get the diagrams & see the differences between the 4 cylinder & the 8 cylinder diagrams. Print them out & put them side by side, & you'll see what the differences are.
Juiced88Coupe
367
Austin, Texas
Jun 3, 2004
  • Jun 3, 2004
I am doing a conversion from a 4 banger and they will not work, much easier to get the correct harness that you need...
beaver2489
503
st. joseph missouri
Jun 3, 2004
  • Jun 3, 2004
ok, thanks guys
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
Jun 3, 2004
  • Jun 3, 2004
If you have your stock SD harness, and the mass air EEC, just get the jumper harness for about $40 and wire it in. They are pretty simple to wire in and allot cheaper than another harness. You can find that junper harness on ebay.
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Fox 5.0 Mustang Tech Apr 13, 2026
Foxbodyjake
F
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
Door wire harnesses 1996 GT
  • Adizzle843
  • Feb 5, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 17, 2026
Adizzle843
