  • SN95 4.6L Mustang Tech
Massachusetts Inspection HELP!
  • Thread starter Thread starter ImportEater98
  • Start date Start date Mar 22, 2004
ImportEater98
708
Worcester, MA
Mar 22, 2004
  • Mar 22, 2004
Hopefully there is a member thats from massachusetts that knows of our *****ty inspection process in this taxfully abundant state. Cutting to the chase....i have an O/R H that would "Visually" pass (welded on Cat casings around the pipe), but will be mincemeat if it hits the rollers. I have the MIL Eliminators keeping the check engine light off...and i used the scan too to check for codes (none found), and to clear the codes...just in case there are some hiding that i can't see. I have heard that on OBDII cars they just plug a scan tool (glorified scan tool) into the port and check for codes. If none appear, you pass the test. If this is the case i am golden...everything else on the car is legit and professional. Any MA residents with words of wisdom?
JonJon
4,801
back in Marylands
Mar 22, 2004
  • Mar 22, 2004
Oh, I hope your tint is legal else you fail. A tint shop told my friend this before he got tinted. So he went legal.
J
JohnyD05
417
Massachusetts
Mar 22, 2004
  • Mar 22, 2004
I failed the Visual, lol. They test the actual emissions only every other year.since your car is a 1998 they only test it on the even years. the bad news its 2004 so its your year, I have heard of older 5.0's passing without cats. but the emissions are way more strict for the newer cars. I brought my car in to have it tested and failed because they did a visual. I bolted my stock h-pipe back up and passed. U get 60 days if u fail, your best bet it to try to pass with your pipes and if u fail bolt on a stock pipe. they also test your car if it was just bought either new or from someone else. so that sort of sucks to. I don't know what to tell you man, good luck. I hate massachuestts.
J
JohnyD05
417
Massachusetts
Mar 22, 2004
  • Mar 22, 2004
I forgot to yell you. for testing they stick sensors into your exhaust pipes
JonJon
4,801
back in Marylands
Mar 23, 2004
  • Mar 23, 2004
Damn. I just got tested this year in MD, all they did was jack into the ODBII and rev'd a few times. Took 5 minutes. Glad my car is registered there!
R
Ron Jeremy
747
Hollywood, California...I live next door to Jenna
Mar 23, 2004
  • Mar 23, 2004
Massachusetts is a Communist state. The liberals want to rob everybody in Massachusetts in order to get money to feed the white trash and the ghetto residents. It's sad but true.
02gtred
146
Phoenix, AZ
Mar 23, 2004
  • Mar 23, 2004
New Jersey laws are pretty strict too. My old mustang (RIP) had an off road x pipe and there was no way they would let me go through inspection and pass with that thing. But I tried anyway. The guy testing the car just looked at me like, 'are you an idiot?' I failed of course so I went home and bolted the stoke H pipe back into place and passed with flying colors. Actually, not flying colors but passing nonetheless. On a side note and a little off topic I had to take my dads acura TL down for inspection. In terms of emissions, the guy said that the car "couldnt kill a chipmunk in a shoebox" where as the mustang could "probably kill an elephant". Just a funny little quote the guy said that made me chuckle. But I would say just save yourself the hassle and put the stock pipe back in place for the day. You will probably have to do it anyway and it will save you the hassle of scraping all the goo off your windshield from the rejected sticker, PITA.
MAC[H]Z
152
NH
Mar 23, 2004
  • Mar 23, 2004
Damn that sucks.... Here in NH they turn on your lights beep the horn and throw a sticker on it...
R
Rider
Lexington, Ky
Mar 23, 2004
  • Mar 23, 2004
Come on down to Kentucky - we have no inspections at all, except when you bring a vehicle into the state and then it is only to confirm the VIN.
J
juicedgt02
24
Boston, MA
Mar 23, 2004
#10
  • Mar 23, 2004
  • #10
not sure if this will help you but we sort of had the same discussion on our local forum http://boston-motorsports.com/forums/showthread.php?threadid=451
ImportEater98
708
Worcester, MA
Mar 23, 2004
#11
  • Mar 23, 2004
  • #11
Hey man....thanks for the link....i'm still unsure...seems like mixed reviews on the process. There was one kid that says he's a licensed inspector, but he doesn't seem to have all the information straight.....ugh....hasn't anyone the right answer? I wouldn't care about getting a rejection sticker (good for 60 days for emissions failure), but then i'll get pulled over all the time for it cuz of suspicious cops, and when i get it reinspected they will go over it with a fine-tooth comb, possibly finding more things they are no satisfied with. Even the Enhanced Emmisions website says in one paragraph that that if i pass the OBDII test and safety i am all set; next paragraph talks about dynoing the car....Anyone been through this? Anyone know of someone that will omit the dyno for me (for the right price, of course)? Thanks for the input guys.
N
notchstang92
58
South Shore, MA
Mar 23, 2004
#12
  • Mar 23, 2004
  • #12
In MA they don't dyno your car every year. Its every other year or when you first buy it. No one will not dyno the car unless its AWD, but they can run another car in your place that will pass if you know yours won't and then put the sticker on your car. Also for window tint I just roll my windows down and they don't check, depending on where you go you may have the same luck. There will be a visual safety check each year and emissions every other year, provided you keep it registerd/insured all year. If you don't then each year you reinsure it you will have to have emissions done again. At least in MA we can tint our door glass, N.J. can't even do that.
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Mar 23, 2004
#13
  • Mar 23, 2004
  • #13
If you try to disconnect the battery to clear the codes, it will show up as "not enough drive cycles" or something like that. Be warned.
ImportEater98
708
Worcester, MA
Mar 23, 2004
#14
  • Mar 23, 2004
  • #14
I plan on using my scan tool and deleting the codes, if there are any......can anyone inspect my car for me? Name your price. Thanks
ImportEater98
708
Worcester, MA
Mar 23, 2004
#15
  • Mar 23, 2004
  • #15
P.S. my windows are legal tint...already checked when they were done
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,058
224
Massachusetts
Mar 23, 2004
#16
  • Mar 23, 2004
  • #16
MA is getting harder and harder to find inspection stations that will "help" you out. It's been a few years now since the stricter standards have been in place and many stations have been caught cheating and got fined up the waazooo.
I basically need to put all my smog equipment back on when it's my time on the rollers. It's a pain in the butt but gotta do what ya gotta do. The station i go to doesn't give me the visual, but it just needs to pass the sniffer. That's about the biggest hook-up i can find these days.
I'm trying to find if Mass has any sort of collector plates or some sort of emmissions exempt program. Best i can find is antique plates at 25 years old. I plan on buying a 03/04 Mustang soon so the 5.0 will be a toy and i don't want to keep going through this pipe-swapping BS all the time on a car i want to basically put a fog-pumping motor into
ImportEater98
708
Worcester, MA
Mar 23, 2004
#17
  • Mar 23, 2004
  • #17
Hey mustang5l5....you mustang looks familiar....i just moved from Ward St. Revere and my car used to be parked out there...if you read my description you probably have seen it. The Gold one in your pictures....does it have a sun coast creations ram air hood on it? If so we've met. Drop me a line.... - Mario
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,058
224
Massachusetts
Mar 23, 2004
#18
  • Mar 23, 2004
  • #18
Yup, does have a ram air hood on it. That's Dave "Ruzman"'s 2000GT and the pics were taken at some pond out near Winchester i beleive.
Drop me a hint to where we met up. I do recognize your car, but i can't put car with place and time and location if you know what i mean. I've just met so many local stang owners off here i forget sometimes.
I didn't even notice your location said Revere til you just posted this
ImportEater98
708
Worcester, MA
Mar 24, 2004
#19
  • Mar 24, 2004
  • #19
I met you (or whoever owns the gold GT) on revere beach either last summer or the summer before....let me see if i can find a pic of my car for you. I friends are all in Clean Machines Auto Club if you've heard of us. Used to be down Dunks next to the Marsh on Squire road all the time...with a white twin turbo camaro. Ring a bell?
Mustang5L5
Mod Dude
Feb 18, 2001
43,330
18,058
224
Massachusetts
Mar 25, 2004
#20
  • Mar 25, 2004
  • #20
Ah, ok i'm starting to remember now. Shoot me a picture though cuz i'm still hazy. I knew a few people in the CMAC but this was a while ago. I've lost touch with a few of em. The "Mustang Thing" kinda died down a lot around Revere as the "Import thing" took over, especially down Revere beach. A lot of my friends no longer own them so i usually cruise with people i meet off here
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
C
Ecu gauges iac and egr problems please help
  • Crockettg24
  • Feb 3, 2020
1996 - 2004 SN95 Mustang -General/Talk- Feb 3, 2020
Crockettg24
C
C
Finally got this horse to pass NJ inspection !!!
  • Clampett5
  • May 18, 2019
SN95 4.6L Mustang Tech May 18, 2019
Clampett5
C
R
Need Help With 4.6 Emission Problems
  • Ranco
  • Jun 1, 2017
2K
SN95 4.6L Mustang Tech Jun 2, 2017
Ranco
R
D
Warning: Tfi Control Module Monkey Business
  • DuderMcMerican
  • Jun 18, 2016
  • 2 3
45K
Fox 5.0 Mustang Tech Sep 20, 2017
jrichker
