Matt's Humble Fox
What do you think?
  • More Detail!!
    Votes: 5 100.0%
  • Less Detail!!
    Votes: 0 0.0%
  • Total voters
So I decided to go the route of lacquer putty to skim the whole nose pretty much,
while that was drying up i pounded a couple layers of epoxy into the door cavities...
then i hit the spoiler...
and then I hit the nose and bumper
Reactions: 4 users
You must have all the time in the world Matt. You should fly down to Abq and help me with my car! It’s all in the prep!!
Reactions: 1 user
lol thanks man! I guess it seems that way:confused: ! I did alot of work over a few weeks and i took pictures of everything and i'm still cataloging it all, i should have done better prep though man i know she's a short hair and panel bond queen but i'm ok with it:shrug:. i'm learning to weld now so one day i can give a car the proper ground up restoration i'm coming to understand!
After letting the primer cure up I hit everything with short strand to give them a little strength
i put a straight edge on the door panel and clamped it together see if the filler will hold maybe...
started grinding down the hatch and found some weak spots... surprise! lol
Reactions: 1 user
Once i got all the prep done on the panels and let the primer set up i started spraying stuff out
The quality of the photos is just stellar :doh:
the spoiler came out pretty good..
and the inner door panel repairs held in nice for some good mil thickness on there...
The bumper covers :rock:
Reactions: 7 users
Thanks! Yeah it’s pretty easy to work with, i picked up a devilbiss starting line gravity feed hvlp kit, for a couple hundred on ebay, came with a couple needles and a touch up gun , it’s pretty good for the price I think...
That seems like a pretty good deal. 1.3 tip? I tested a Devilbiss gun for a bit before deciding to go with a couple of Iwatta brand guns. I spray waterborne paint at work. A coworker of mine uses a Devilbiss gun every day though and it seems like a good quality option.
Yeah 1.3 , and a 1.6 for higher builds, i like it, its entry level but thats all I could spring for. they have a finishline”kit which looked good but it is quite a bit more. But im not spraying alot either so.
So i started prepping the hatch and such...
The doors had some pretty bad wow spots...
and then i was dumb and forgot to take pictures of spraying the doors and hatch :mad:...so i started re-assembling the shell..
heres hatch and spoiler, tailights in..
I did a little test panel for the stripping which i think i like in gloss black, should look sharp
Reactions: 2 users
