Is this a daily driver?
how much time will it be on the freeway?
is the car going to be heavy? ie:a/c,insulation,lot's of stereo,p/s,late model seats etc.
I look at all of the picture before choosing gears, If you live in area that the highway speed is 55-60 mph vs.75-80mph this all weighs into perspective.
if the car is light you can run 3:25's
if your not intrested in freeway cruisng you can run 3:89's
I built my 331 motor to come onto cam around 2500 rpm and at freeway speed it's right around 75mph. Most people will say that boging a motor will hurt the bottom end bearings as well as the rings so I decided that2500 would be a safe cruising rpm
a 393 motor doesn't need supper low gears to multiply torque like a 302 or 289.
if your useing a tranny that's not a overdrive you could run a 3:00 to 3:25 gear all day long with out issues I have a tremec with 4:11's first gear is way too low like 13 to 1! and final gear drops to 2.79 to 1 it's great on the highway I'ld love to have the new tremec 500 or 600 they have a tighter ratio would make it a easier trying to come up with the right ratio for the rear gear
