I'm building a 302 for my car, not for daily driving, but still streetable. Everything I have read seems to indicate that the higher the compression ratio, the better the car will run. Of course too much and you detonate.
So what is the most you can run on 91 octane with aluminum heads? I'm going to get my heads decked so I can get pretty much any ratio I want once I do the math. What other factors come into play? I know elevation, temperature, humidity, and a lot of other things like that probably tweak the theoretical ratio a little, but I'm just wondering about a safe non-detonating ratio to run in general. I'm going to run some nitrous too if that helps.
The 2031 is also a smog cam without much overlap to bleed the compression off.
